HWSW Informatikai Kerekasztal: Bittorrent - HWSW Informatikai Kerekasztal
  • (148 Oldal)
Bittorrent Néha nem tölt...
#1 Felhasználó inaktív   lac1
Elküldve: 2004. 10. 06. 09:47
Azureus-t használok, és néha amikor a welapon a torrent linkre kattintok, akkor a letöltőben nem a torrent file neve jelenik meg, hanem az hogy az a file a sajátgép /felhasználó/temp.int.filesbe rakja.
És persze nem tölt. Ha torrentet megkeresem, és ott kattintok rá akkor ez jelenik meg egy böngésző ablakban:
Unauthorized download
We're sorry, but this downlod request cannot be authorized. There could be several reasons for this:
1) You clicked on a link on an *unofficial* SuprNova.org mirror. We do not allow that kind of external hotlinking. This site creates a great deal of traffic and it's hard to find a good hosting. We will not provide the bandwith for other sites. Please visit SuprNova.org and you can download all the torrents you want.
2) You're using a download manager. But there's a solution to this problem:
Set up your download manager to send a HTTP referer, and when you click on a link on the SuprNova.org site the download will be authorized. Here's how you can do this in Getright:
Go to Getright Configuration, under Advanced/Protocol check Send "Referer" in HTTP Request and then select Calculated from open web browser page.
The setup should be similar for other download managers.
3) Your browser did not send a referer. This normally happens if you right click on a link and select save-as, or if you copy and paste a link into a new browser window and press Enter. It may also be that your browser is set up to not send any referer. But left clicking on a link works just fine and has been tested in IE6, Netscape 6, Opera6, Firefox and Safari
Some software firewalls, for instance the Norton Personal Firewall (which is also part of Norton Internet Security) or ZoneAlarm remove the referer from HTTP requests which will block any downloads on any site that does a referer check. Hence such options should always be turned off. In Norton you have to go to the Privacy Settings and disable browser privacy (which doesn't really protect your privacy anyway as your IP address will always be logged regardless of that setting), in ZoneAlarm you have to go to Privacy -> Cookie Control -> Custom and uncheck "remove private header information".
Software like AdSubstract also blocks the referer and makes downloads impossible.
We're sorry for any inconvenience this may cause and hope you understand our reasons for doing so. Bandwith doesn't come cheap and we have to do all we can to keep the bandwith usage down.
Tud valaki segíteni, higy ez mit jelent, mi a hiba?
köszönöm.
#2 Felhasználó inaktív   Kuroimaho
Elküldve: 2004. 10. 08. 18:15
Volt a mirrorokkal problema. Mar mukodik, a torrentet probald lementeni.
Korrektorom Klikodesh
No one cares if you're asian unless you're female.
玉置浩二 - 愛されたいだけさ
#3 Felhasználó inaktív   Gyulavitéz
Elküldve: 2004. 10. 11. 12:31
Szerintem ez lehetett a hiba. Nálam IE alatt nem működik a torrent fájlok letöltése, biztosan valami magasra van a biztonság állítva (nem tudom, mert csak egyszer véletlenül használtam az IE-t, ált firefox-ot használok).
<a href='http://notik.hu' target='_blank'>bontott notebook alkatrészek</a>
#4 Felhasználó inaktív   eddie
Elküldve: 2004. 10. 11. 20:44
Idézet: Gyulavitéz - Dátum: 2004. okt. 11., hétfő - 13:31
Nálam is itt volt a kutya elásva ("3) Your browser did not send a referer."). Ha torrentet akarok tőlük letölteni, akkor a Kerio-n engedélyezem a "Deny servers to trace web-browsing"-ot és már mehet is a letöltés az Operával.
#5 Felhasználó inaktív   lac1
Elküldve: 2004. 10. 12. 10:05
Csakhogy nekem az egyik torrent lejön, a következő meg nem. És az a hiba, mondom, hogy a Azureus ban nem a torrent neve jelenik meg, hanem az az útvonal ahová a terrentet menti .
És persze nem tölt.
#6 Felhasználó inaktív   Netmaster
Hozzászólás ikon  Elküldve: 2004. 10. 12. 13:43
Idézet: lac1 - Dátum: 2004. okt. 12., kedd - 11:05
És persze nem tölt.
Ennek ellenére nincs köze a BitTorrenthez. A böngésződ nem megfelelően küldi a referrert, így a torrent file helyett kapsz valami html oldalt, azt meg nem csoda, ha nem tudja értelmezni az Azureus.
#7 Felhasználó inaktív   Gyulavitéz
Elküldve: 2004. 10. 14. 06:51
Nem lehetséges, hogy olyan torrentet akarsz letölteni, amihez regisztráció, esetleg fizető tagság szükséges?
#8 Felhasználó inaktív   Kuroimaho
Elküldve: 2004. 10. 14. 09:29
Reg trackerhez kell nem torrenthez.
玉置浩二 - 愛されたいだけさ
#9 Felhasználó inaktív   lac1
Elküldve: 2004. 10. 14. 09:50
Idézet: Netmaster - Dátum: 2004. okt. 12., kedd - 12:43
Nem, mert egy .torrentet kapok.
példa:
happy.tree.friends.dvdripp-et. / keresés /
#10 Felhasználó inaktív   lac1
Elküldve: 2004. 10. 14. 09:51
Ja elfeljetettem a suprnova-ról.
#11 Felhasználó inaktív   Kuroimaho
Elküldve: 2004. 10. 14. 15:01
Happy Tree Friends Vol. 2 DVD trackerhez reg kell. A tobbi mind ment nekem amit supernovan talaltam.
玉置浩二 - 愛されたいだけさ
#12 Felhasználó inaktív   Netmaster
Hozzászólás ikon  Elküldve: 2004. 10. 16. 09:49
Idézet: lac1 - Dátum: 2004. okt. 14., csütörtök - 10:50
Nézz bele abba a torrentbe egy Jegyzettömbbel. Lehet, hogy mégsem torrent az :p.
Ha a jelszó lenne a gond, azt a trackerhez csatlakozáskor kérné, nem letöltéskor.
Szerkesztette: Netmaster 2004. 10. 16. 09:50 -kor
#13 Felhasználó inaktív   Gyulavitéz
Elküldve: 2004. 10. 18. 12:57
igen, valszeg letölti neked a .torrentet, de a nyitóhozzászólásban szereplő tartalommal (már ha a suprnováról töldöd).
a bittornádót használom, és alul ki van írva, hogy "tip: your download rate is proportion of your upload rate."
mennyit jelent ez számszerint? sehol sem találtam róla semmit, és nem is jövök rá a sebességekből.
#14 Felhasználó inaktív   lac1
Elküldve: 2004. 10. 19. 10:49
Idézet: Kuroimaho - Dátum: 2004. okt. 14., csütörtök - 14:01
Vagy egy másik a combat flight simulator.
Mellesleg feltöltés / upload / sebesség limt beallításaával most megpróbálkozom...
Van másik torrent is ami ezt csinálja, de most hirtelen ezt találtam.
#15 Felhasználó inaktív   Pietrosz
Elküldve: 2004. 10. 29. 20:26
Helló!
Ha esetleg valakinek gondja lenne a sebességgel, az nézzen el ide
Hasznos.
- Where are we going?
- Let's go find out.
#16 Felhasználó inaktív   gbr
Elküldve: 2004. 10. 29. 22:37
most kezdtem a torrentezést és lenne egy kérdésem, arra rájöttem hogy a fileokban az adatok relative összevissza vannak, szóval hiába tud a winamp megnyitni egy mp3-mat össze vissza van benne mindenből egy kicsi, ezt mikor rakja rendbe a letöltő kliens? ha vége a letöltésnek vagy ha egyszerüen bezárom? esetleg el lehet érni hogy ne így csinálja?
#17 Felhasználó inaktív   Pietrosz
Elküldve: 2004. 10. 29. 23:03
Idézet: gbr - Dátum: 2004. okt. 29., péntek - 23:37
Hali!
Azureus-ban be lehet állítani, hogy a fájl elejét töltse először, hogy bele lehessen nézni, de ez a legtöbbször nem működik. Csak akkor lesz "rendberakva" a fájl, ha teljesen letöltődik (ekkor nem maradnak benne lyukak :) ) . A fenti linket megnézted? Nem egyszerű belőni a pontos értékeket, de megéri szórakozni vele.
#18 Felhasználó inaktív   desiderii
Elküldve: 2004. 11. 03. 21:07
Van olyan tracker, amelyik megőrzi a letöltött adatokat, ha lefagy a gép?
Mert így sose fog lejönni egy file se, ha mindig 0-ról kell indulnom. :(
(A BitTornado sajnos egyértelműen nem tartozik ezek közé.)
#19 Felhasználó inaktív   Pietrosz
Elküldve: 2004. 11. 03. 21:49
Idézet: desiderii - Dátum: 2004. nov. 3., szerda - 21:07
Nem tracker kell neked, hanem kliensprogi.
Próbáld az azureust vagy a bitcometet
#20 Felhasználó inaktív   gbr
Elküldve: 2004. 11. 03. 21:55
én Burst! használok kliensnek, az simán folytatja.
  • (148 Oldal)
