HWSW Informatikai Kerekasztal: Eladó 19" LCD monitor Fujitsu Siemens model:L9ZA - HWSW Informatikai Kerekasztal
#1 Felhasználó inaktív   redsas
Elküldve: 2011. 04. 30. 07:19
Analóg/DVI kimenet
Ár:20000ft
redsas
#2 Felhasználó inaktív   redsas
Elküldve: 2011. 04. 30. 14:34
Monitor pontos neve Fujitsu-Siemens ScaleoView L19-2SD
redsas
#3 Felhasználó inaktív   redsas
Elküldve: 2011. 05. 01. 06:37
General
Display Type LCD display / TFT active matrix
Built-in Devices Stereo speakers
Width 41 cm
Depth 21.4 cm
Height 37.5 cm
Weight 4.5 kg
Enclosure Colour ( the image of the product displayed may be of a different colour )
Display
Diagonal Size 19"
Viewable Size 19"
Dot Pitch / Pixel Pitch 0.294 mm
Max Resolution 1280 x 1024
Colour Support 16.2 million colours
Max Sync Rate (V x H) 75 Hz x 81 kHz
Response Time 5 ms
Controls / Adjustments Volume, brightness, contrast, H/V position, colour temperature
Display Positions Adjustments Tilt
OSD Languages English, German, French, Italian, Polish, Russian, Spanish, Dutch
Backlight Life 50,000 hour(s)
Signal Input DVI-D, VGA
Image Brightness 300 cd/m2
Image Contrast Ratio 800:1
Image Max H-View Angle 160
Image Max V-View Angle 160
Video Input
Analogue video Signal RGB
Digital Video Standard Digital Visual Interface (DVI)
Audio Output
Type Speaker(s) - stereo - integrated
Output Power / Channel 1 Watt
Expansion / Connectivity
Interfaces 1 x VGA - 15 pin HD D-Sub (HD-15)
1 x DVI-D - 24 pin digital DVI
1 x audio line-in - mini-phone stereo 3.5 mm
Miscellaneous
Cables Included 1 x VGA cable - 1.8 m
1 x audio cable - 1.8 m
Flat Panel Mount Interface 100 x 100 mm
MTBF 70,000 hour(s)
Features Security lock slot (cable lock sold separately)
Compliant Standards Plug and Play, FCC Class B certified, CE, DDC-2B, EN 60950, EN 61000-3-2, GS, ISO 13406-2, NEMKO, TCO '99, VESA FPMPMI, EN 61000-3-3, EN50082-1, EN55022 Class B, FCC Part 15
Power
Form Factor Internal
Voltage Required AC 120/230 V ( 50 - 60 Hz )
Power Consumption Operational 50 Watt
Power Consumption Stand by / Sleep 1 Watt
Environmental Standards
ENERGY STAR Qualified Yes
Environmental Parameters
Min Operating Temperature 5 °C
Max Operating Temperature 35 °C
redsas
#4 Felhasználó inaktív   redsas
Elküldve: 2011. 05. 02. 15:39
:up:
redsas
#5 Felhasználó inaktív   redsas
Elküldve: 2011. 05. 02. 20:03
17000ft :up:
redsas
#6 Felhasználó inaktív   redsas
Elküldve: 2011. 05. 02. 20:33
Idézet: redsas - Dátum: 2011. 05. 02. 20:03
15000ft :up:
redsas
#7 Felhasználó inaktív   redsas
Elküldve: 2011. 05. 03. 18:39
:up:
redsas
#8 Felhasználó inaktív   redsas
Elküldve: 2011. 05. 04. 08:06
14000ft
redsas
#9 Felhasználó inaktív   redsas
Elküldve: 2011. 05. 06. 15:37
:up:
redsas
#10 Felhasználó inaktív   carr
Elküldve: 2011. 05. 08. 22:40
Ment pü. :)
#11 Felhasználó inaktív   carr
Elküldve: 2011. 05. 19. 21:35
Ment emil, meg pü!
