HWSW Informatikai Kerekasztal: NVIDIA NV50 - találgatások és tények - HWSW Informatikai Kerekasztal
  • (13 Oldal)
NVIDIA NV50 - találgatások és tények a hetedik GeForce generáció... Értékeld a témát: -----
#1 Felhasználó inaktív   max-pain
Elküldve: 2004. 08. 26. 10:12
http://beyond3d.com/...pic.php?t=15518
Following the Games Convention in Leipzig golem.de is reporting that following the launch of GeForce 6600 NVIDIA will move the NV4x range into the low end segment, replacing the 5200 series with an NV4x based version, and an notebook NV4x part will soon to be introduced on the NVIDIA MXM notebook video board format - a look at the PCI Express Integrators List shows NV43M, indicating that the mobile part coming first is a version of the 6600. However, evidently NVIDIA have signalled the end to the 12 month architectural cycle.
In statement that echoed ATI's previous sentiments, NVIDIA are suggesting that due to chip complexities and lithography cycle times architectural innovation times will be pushed out to about 18 months. Although NVIDIA are suggesting similar things to ATI now, if we look at NVIDIA's NV2x and NV3x generations, they have been on greater than 12 month cycles for the past two generations anyway (taking into account that NV30 was launched in November 2002, which was probably close to its intended introduction). This being the case, given NV40's announcement and wide scale availability, it would suggest that the NV50 series will not be announced until late 2005 with possible wide scale availability in 2006. NVIDIA have already stated to their investors that the low end NV4x parts will last for up to 3 years, indicating that the NV5x range will remain the domain of the high end segments and that NV4x will stay around until "Windows Graphics Foundation" in Micorsofts next geneteration OS, Longhorn.
The release of Longhorn will also be critical to both NVIDIA and ATI's plans - given the timing and the fact that there are not to be any low end NV5x, this may suggest that NV5x is set to be an extended Shader 3.0 architecture, which would indicate that the further Longhorn moves into 2007 the better it would suit NVIDIA's architectural innovation cycle. Presently the expectation is that ATI will introduce their Shader 3.0 part, suggested to be primarily developed by the R300 architectural team, in mid 2005 - ATI may be a little off their 18 month cycle as they chose not to innovate as much this cycle in order to hit the PCI Express transition - and that would also suggest that "R600" based parts would come in the late 2006 / early 2007 period. Regardless of longterm exrapolated timescales, though, its likely that both vendors will attempt to hit as close to the introduction of Longhorn as possible.
Szerkesztette: max-pain 2004. 08. 26. 10:15 -kor
#2 Felhasználó inaktív   azopi
Elküldve: 2004. 08. 26. 11:56
Nem korai ez még egy kicsit? :)
Egyébként ami várható az új generációs kártyáktól (akár nVidia, akár ATi):
SM 4.0, CSC (Common Shader Core - egségesített shaderek)
teljesen rugalmasan programozható, általános célú ALUk sokaságává válik a GPU, átveszi az ütközés-felismerést és a fizikát a CPU-tól, A shaderek egyre komplexebb volta miatt kizárólag valamilyen magasabb szintő programnyelven érdemes megírni azokat (Cg vagy HLSL), a CPU terhe lesz viszont ezeket a shadereket futási időben fordítani a GPU számára (amíg bele nem raknak a GPU-ba egy shader-fordító egységet :)). Primitive processzor. Virtuális memória-kezelés, multitaszking.
Ezeket csak onnan tudom, hogy ezek állnak jelenleg fejlesztés alatt a Microsoftnál a Directx Next és Windows Graphics Foundation fejlesztőcsapatainál, tehát a köv. generációs GPU-knak illik majd ismerni ezeket a ficsöröket. Persze specifikációkról még pletykaszinten sem hallani, még annyira messze a megjelenés. Ez valószínű, hogy addigra a 90 nanos tech kiforrja magát, és széles körben elérhető lesz (a foundryknál is) Tehát a tranyószám várhatóan 300-350M körül alakulhat.
#3 Felhasználó inaktív   max-pain
Elküldve: 2004. 08. 26. 12:04
Ez csak a kovetkezo generacio utan varhato :)
Egyebkent a B3D forumaban azt olvastam, hogy David Kirk (egyelore) a unified shader architecture ellen van...
#4 Felhasználó inaktív   azopi
Elküldve: 2004. 08. 26. 14:22
Idézet: max-pain - Dátum: 2004. aug. 26., csütörtök - 11:04
Ez érdekes. Ugyanis a Fudo (R500) holtbiztos, hogy egységesített shader architektúra lesz. Nem hiszem, hogy az nV megkockáztatná, hogy ennyire lemaradjon az ATI-tól technológiailag. Legkésőbb a Longhorn megjelenéséig pedig muszáj lesz kint lenniük egy DX Next Compliant chippel, ahol pedig követelmény a CSC.
#5 Felhasználó inaktív   max-pain
Elküldve: 2004. 08. 26. 16:09
Elvileg az R520 (Fudo) meg nem lesz egysegesitett shader architektura.
Az Xbox 2-ben levo "R500" viszont a pletyik szerint az lesz, de PC-ben ez majd csak az R600-ban fog debutalni. A Longhorn ugysem varhato 2006 vege elott...
Szerkesztette: max-pain 2004. 08. 26. 16:10 -kor
#6 Felhasználó inaktív   Hasse
Elküldve: 2005. 04. 16. 09:54
ATi and NVIDIA are certainly working hard to push out their next generation GPUs for Computex launch in June. NVIDIA is particular tight-lipped about their NV50/G70 GPU even to their partners while ATi has not demo a working sample to their partners till now so things aren't looking too rosy. None the least, we heard that NV50/G70 is a dual-core monster with 32 pipelines and is based on TSMC 90nm process technology. ATi R520 is also 90nm based and contains 32 pipelines. The reference cooler design for NV50/G70 looks huge with 4 copper heat-pipes and a large fan.. We have also heard about an interesting strategy that NVIDIA is going to equip their next generation cards ranging from low-end to high-end with 2nd gen. Turbo Cache technology.
Next Gen GPUs Info : R520 & NV50/G70
A fiktív "kimondnagyobbszámot" 3DMark05 versenyben egyelőre az NVidia vezet...
...5%-al az R520 előtt.
#7 Felhasználó inaktív   joshua7
Elküldve: 2005. 04. 16. 17:53
Idézet: Hasse - Dátum: 2005. ápr. 16., szombat - 10:54
SLI nv50= 30000 pötty 3dmark05-ben.  :)
Semper Fi
#8 Felhasználó inaktív   Frosty
Elküldve: 2005. 04. 20. 15:00
A nyár valóban forró lehet a videokártyák piacán is, hiszen mind az ATI, mind az NVIDIA ekkorra szeretné időzíteni új generációs videokártyáinak megjelenését.
A the Inquirer és a VR-Zone oldalain belső forrásokra hivatkozva újabb információmorzsákra bukkanhatunk az NVIDIA új, NV50/G70 GPU-ra épülő megoldásáról. A duál magos szörnyeteg 32 pixel csővezetéket tartalmaz (csakúgy mint az új ATI mag), és a TSMC 90nm-es technológiájával készül majd. Az NVIDIA referencia hűtése egy óriási, 4 hőcsöves rézhűtés lesz, egy jókora méretű ventilátorral a tetején. Érdekesség még, hogy a cég az új sorozattal nem csak a felső és középkategóriát fedi majd le, hanem az alsó kategóriába is kínálni fog megoldásokat, melyekbe már a második generációs Turbo Cache technológiát is beépítik.
:eek: :OOO
Asus P8Z68-V, Intel Core i5 2500K@4.5GHz,Corsair A70 cooler, 2*4GB Kingston HyperX Blu XMP 1600MHz @ 1.5V, Sapphire 7970 OC Dual-X, Asus Xonar DX, Corsair AX750 750W, Creative Megaworks 550, Samsung 1TB F1 HDD, Dell U2311H
#9 Felhasználó inaktív   -Turbo-
Elküldve: 2005. 04. 20. 15:02
hmm, no, azt megnézném! :)
JóSebesség
#10 Felhasználó inaktív   Frosty
Elküldve: 2005. 04. 20. 15:06
Ha tényleg ilyen hűtés lesz rajta akkor legalább nem kell venni rá mást. :)
#11 Felhasználó inaktív   -Turbo-
Elküldve: 2005. 04. 20. 15:08
és vajh' hány pci-e helyet fog foglalni? :D
JóSebesség
#12 Felhasználó inaktív   joshua7
Elküldve: 2005. 04. 20. 16:03
Az összeset!  :)
Semper Fi
#13 Felhasználó inaktív   Shane 54
Elküldve: 2005. 04. 20. 16:17
áhh....vicc az egész....majd csak kiderül mi is a frankó, addig meg....gyűjthetünk rá maximum :Đ
mire megjön addigra meglesz a zsé 1% kb mindenkinek :D
Találjuk meg együtt az AIDS ellenszerét!!
Csatlakozz a magyar csapathoz!!
"...nehogy már a fika egye meg az óvodást..." Andro, részlet
Gondolkodtál ma már?
#14 Felhasználó inaktív   JoCkAs
Elküldve: 2005. 04. 20. 16:37
Akkor ezekszerint az NV folytatja a hűtés problémáit... :eek:
Azért kiváncsi lennék, hogy az Atinak milyen hűtés kell majd a kártyájára...
Enermax Modu82+ 425W PSU;Asus P5K;Intel Core 2 Duo E8200 2,66Ghz;Creative SB Audigy Player;Pioneer 216D;WD 200GB/8MB IDE;WD 320GB/16MB SATA;2x2x1GB GEIL 1066 DDR2;Samsung SyncMaster T200 ;Asus ATi Radeon HD3850 256MB
#15 Felhasználó inaktív   JoCkAs
Elküldve: 2005. 04. 20. 16:39
Idézet: joshua7 - Dátum: 2005. ápr. 20., szerda - 17:03
Az összeset!  :)
De csak a hűtés miatt...meg kell valaminek tartania a káryát is.... :D  Különben ketté törik... :D
#16 Felhasználó inaktív   JoCkAs
Elküldve: 2005. 04. 20. 16:40
Idézet: Frosty - Dátum: 2005. ápr. 20., szerda - 16:06
:D  :D De legalább a gépbe nem kell venni mást....már nem marad hely másnak! :D  Hát ez  :lol:
#17 Felhasználó inaktív   -Turbo-
Elküldve: 2005. 04. 20. 16:41
Idézet: JoCkAs - Dátum: 2005. ápr. 20., szerda - 17:37
kedves Jockas! milyen problémái vannak az NV-nek a hűtéssel?  :think:
JóSebesség
#18 Felhasználó inaktív   JoCkAs
Elküldve: 2005. 04. 20. 16:43
Idézet: -Turbo- - Dátum: 2005. ápr. 20., szerda - 17:41
Azon kivül, hogy az alap hűtés elfoglal két slotot?
#19 Felhasználó inaktív   -Turbo-
Elküldve: 2005. 04. 20. 16:46
Igen? Bizonyíts!
JóSebesség
#20 Felhasználó inaktív   JoCkAs
Most már jönnek a hőcsöves megoldással...legközelebb mi lesz?! Egy vízhűtés? :eek:
ui: A GF6-os szériának már egy kicsit jobb megoldása volt az előtte lévő FX-en lévőnél...
De azért a GF4 sem volt mentes a hűtési problémától...
  • (13 Oldal)
